Old 06-06-2010, 09:04 PM   #1
OMGshawn
OMGshawn's Avatar
Member #10187
87 Rx7 T2, 88 Rx7, 90 S13
Send a message via AIM to OMGshawn
My s13 build...vh/suede/tubs/wire tuck 56k no way
Wanted to redo my build thread..to many pictures and going a complete different direction so mods feel free to close/delete/whatever my old thread
This is her when I first picked her up
UGLY interior.
I removed the tach, swapped steering wheels, swapped in S14 seats, did the headunit wiring, removed the nasty cloth on the door panels, had my gf make me a banging bandanna shift boot and cleaned the **** out of everything.
I ended up swapping wheels with my friend which brought me here
Then got a system together..
And got this
Added some Cusco Comp S's..
My favorite 'stage' that the car was in
Rocked it like that for a little..
Moved the plate
And got this stuff
Nismo mounts(for sale)
OEM tob
Then bought this
Painted..
Then I got the car up on jack stands and started tearing her apart
And I'm left with this..
Old
New
Started cleaning the bay
And got a short shifter
Got it all back together and running...found out the trans I bought was shot...so back onto the jackstands it went and a new trans was put in
Fixed and primed the hatch
Done
Engine..
Interior
Also got this
And this
S14 seats hurt my back(was in a bad car accident) so I swapped them back(dirty I know)
Zero for me, but about six times a day I...
JIZZ IN MY PANTS!
OMGshawn is offline   Reply With Quote
Old 06-06-2010, 09:05 PM   #2
OMGshawn
OMGshawn's Avatar
Member #10187
Anddd around here is where the engine blew....not even 200 miles after it was swapped
The engine was 'refreshed' I pulled the usual stuff off didn't look bad so I put it in. Turns out revious owner RTV'd the **** out of everything(front cover, oil pan, upper front cover), and it came off on the inside and completely plugged the oil pick up tube...
This seems oddly familiar
Bought this..
Together..
Started some porting on the head
Pre surgery
The start(again)
JIZZ IN MY PANTS!
Old 06-06-2010, 09:06 PM   #3
OMGshawn
OMGshawn's Avatar
Member #10187
And here is about where I decided to go v8...
Then it turned into a full build
Interior out
Decided to do all black suede so started that..
(still needs the insert done, doing it gucci)
Pulled the carpet and stuff
Painted the dash bar
And dyed the carpets
And got some diamond racing 15's..(for sale probably)
More stripping
It was fully wire wheeled, don't really have any pictures of it..
Then primed
Rust cut out
Hatch primed almost done
Sound deadening
DCC bought/wired up
Relocating the fuse box under the dash/by the toe boards..
One half
Andd the other
Stripped most of the **** off the firewall...did I mention I'm stitch welding the inside and engine bay also?
Main harness work..
Fuse panels I'm using..
Diagram I was working on
And that's about where I'm at, hopefully have updates in a day or 2
JIZZ IN MY PANTS!
Old 06-07-2010, 07:54 AM   #4
M Solo
M Solo's Avatar
Member #14194
My Nikes
wow dude
awesome job so far
cant wait to see the finished product
*formerly Blown GK*
03 V6 GK
Dropped & Blown
M Solo is offline   Reply With Quote
Old 06-07-2010, 08:08 AM   #5
redtoprps13
redtoprps13's Avatar
Member #7485
1998 integra ls/1993 eg hatch
Send a message via AIM to redtoprps13
so...when am i paying you to do my car?
redtoprps13 is offline   Reply With Quote
Old 06-07-2010, 06:43 PM   #6
OMGshawn
OMGshawn's Avatar
Member #10187
Thanks
And redtop - whenever you want lol
JIZZ IN MY PANTS!
Old 06-07-2010, 07:04 PM   #7
s2kguy17
Member #15353
how did you get the suede to go around the dash so good? i thought you had to stitch the corners?
s2kguy17 is offline   Reply With Quote
Old 06-07-2010, 07:23 PM   #8
OMGshawn
OMGshawn's Avatar
Member #10187
Yeah, it can't be one piece around the corners, it just won't work. I cut it and over lapped the edges, it's noticeable but not badly...I'm getting a HUD dash to go with the cluster and am going to redo the suede but with red stitching this time
Engine bay currently..
JIZZ IN MY PANTS!
Old 06-07-2010, 10:10 PM   #9
vladimir
vladimir's Avatar
Member #16649
MY05 Sti
looks like a fun project! good luck with it.
vladimir is offline   Reply With Quote
Old 06-08-2010, 11:52 AM   #10
OBEEWON
OBEEWON's Avatar
Member #1315
Lansdale Local
Stuff is looking right.
E .· \' ' ·. F
Old 06-08-2010, 12:03 PM   #11
thefro526
thefro526's Avatar
Member #7892
1996 240sx & 1989 240sx Coupe
Looks like a pretty rad build.
I was going to do a VH45 S13 once and then got away from it due to the lack of aftermarket support for the motor at the time.
What are you doing for the transmission? Mazworx? Dixon? Custom?
I had a Dixon plate that I was going to use on my swap, and it's my favorite way to adapt a Z32 Transmission to a VH. I actually sold the Dixon plate to a member on here.
thefro526 is offline   Reply With Quote
Old 06-08-2010, 04:19 PM   #12
OMGshawn
OMGshawn's Avatar
Member #10187
I'm going to be running a z32 trans with machining from Mazworx along with their driveshaft. I'll be making the mounts myself, don't like how the mazworx ones look.
Todays works..
And pulled the trans and stuff
JIZZ IN MY PANTS!
Old 06-10-2010, 06:16 PM   #13
OMGshawn
OMGshawn's Avatar
Member #10187
Started pulling the rear apart..
Wow..can't believe I cruised at 110mph for over 2 hours with this thing >_< I really hate PO's
Gonna redo it, completely...
JIZZ IN MY PANTS!
Old 06-17-2010, 11:11 PM   #14
OMGshawn
OMGshawn's Avatar
Member #10187
Pulled the back apart...dirty as hell in there lol
Going to get a nice cleaning tomorrow
Fresh out
Ready for some plastic polish..gonna make these babys like new
Pulled the tank. It actually looks good in there, lol.
I was expecting it to be bad, judging from the rest of the car.. I guess I'm just going to clean it up, re coat it, and still use it. If it was bad, I was going to cut the floor out, run a cell/external pump/AN lines all the way to the engine bay, which would be $5-600 to do the way I wanted, but since it's good I'll put the money towards something else for now and do that later on down the road.
Also, did I mention I love wiring?
Stripping out the rear wiper, antenna, the rest of the seat belt system and anything else I come across
Stripped and laid out(somewhat lol) on the table, pulled the front harness off it because this will be done soon
What was pulled out so far, still didn't get to the dash side of the harness
JIZZ IN MY PANTS!
Old 06-17-2010, 11:30 PM   #15
Nick Merrone
Member #10807
c18det hatch
looking good...
Old 06-17-2010, 11:31 PM   #16
AristoSan
AristoSan's Avatar
Member #10650
Boosted 2001 GS300
you are nuts...
AristoSan is offline   Reply With Quote
Old 06-18-2010, 12:09 AM   #17
mo_hish
Member #10390
VGT S13.5
This is going to be awesome. I can just feel it.
mo_hish is offline   Reply With Quote
Old 06-18-2010, 04:35 PM   #18
OMGshawn
OMGshawn's Avatar
Member #10187
Haha I hope and thanks
Gonna try to finish up the interior harness today..maybe do some more on the front harness
JIZZ IN MY PANTS!
Old 06-23-2010, 04:23 AM   #19
OMGshawn
OMGshawn's Avatar
Member #10187
Getting ready for new bushings, media blasting and powder coating..
JIZZ IN MY PANTS!
Old 06-23-2010, 08:09 AM   #20
TNTramair
TNTramair's Avatar
Member #1299
like seeing stuff like this...subscribing. what V8 power plant do you intend on using...i might have missed it if you posted what it was.?
2000 Trans Am WS.6 m6 402/RKT t56/MWC 9"
2004 Audi A4 Quattro Stock
2012 Camry SE/SE Stock
2006 Yamaha R1 50th ann.
TNTramair is offline   Reply With Quote
OMGshawn's S13 build *DCC/Suede/Primer/Wire tuck.. (last page)* OMGshawn Member Journals 138 06-01-2010 09:40 PM
Wire Tuck Thread! dsturch1 Gallery 5 04-15-2008 06:32 PM
has any1 done a wire tuck jdm free General Car Related Chat 5 03-19-2007 02:50 PM
Help me with a wire tuck! StreetEG Delaware 1 10-22-2006 02:01 PM
anyone wire tuck their bay? igo4bmx General Car Related Chat 5 02-04-2006 11:23 PM
