#1 |
Suspension install hang-ups?
I've accumulated a rather large amount of suspension bits over the past year... it all amounts to; Koni dampers in '02 wagon strut bodies RCE Wagon springs Sedan front control arms Kartboy sedan front end links Whiteline ALK Hotchkis RSB + end links undecided on which FSB I will run I also have rear '04 (less wide than '05+) STi lateral links & sedan rear axles, but don't think I'll be pushing out the track in the rear. Basically, what kind of snags have you run into when installing any/all of these bits? I've heard the control arms can be a beast to get off due to rust, but anything else? I'm planning to spend a weekend on all of it, but am trying not to have it take any longer so want to get any precautionary things out of the way. This is all on a '03 wagon with ~70k miles.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 signatures. |
#2 |
It's been my experience that you should have either the front or the rear completlyoff the ground depending which your working on. Otherwise sway bars and the link have pressure on them and become a pain in the balls.
I didn't do the lateral links on my wagon so I can't tell you much about that. Coilovers/suspension are a breeze. |
#3 | |
My Ride: 07 Bugeye STi - 94 Supra iTrader: (6)
yeah everything looks like it should be pretty straightforward except the control arms can be a bit tricky as you have already mentioned.
there are two options for taking the control arm off... you can also remove the balljoint that goes into the knuckle, or you can leave that balljoint in place. i wanted to put fresh balljoints on my car when i did my swap and thats where the problem was. it was so rusted into place it wouldnt budge. took a day and a half to do my control arms, haha but i finally got it. also, dont know if you've done struts before but sometimes those lower strut bolts can be very tight. you cant normally fit air tools in there and the space you're working in is limited so a breaker bar wont always work either (unless you're on a lift). i sometimes find the right combo of two wrenches and link them together for extra leverage and thats how i break stubborn lower strut bolts loose. good luck...
To view links or images in signatures your post count must be 10 or greater. You currently have 0 signatures. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 signatures. Quote:
To view links or images in signatures your post count must be 10 or greater. You currently have 0 signatures. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 signatures. |
#5 |
Thanks guys. It's nice to be ready for things so that even if there are little idiosyncrasies with the install, at least I'm ready for them.
I have a spring compressor but don't have any air tools. Is it worth it to try and bribe someone with air tools to let me work on it at their place or borrow something if possible?
#7 |
Honestly I would forget the control arms, The hassle to gain ratio isnt strong lol. If I were you I would put the struts and springs together prior to the whole install because having a drop in suspension can turn a 4hr install into a 1hr install. Also, RSB brackets are whores. they mount right above the charcoal canister and inbetween it an the tube to the gastank. it sucks, I cussed alot on that install. Make sure the bolts on the endlinks are tight to the endlink, I ran into a situation where they lost nuts or broke the bolts.
III To view links or images in signatures your post count must be 10 or greater. You currently have 0 signatures. |
#8 |
good luck with the rear lateral links. There is a 12" long bolt going through the hub that ALWAYS freezes in there. I have only had 1 car that actually had it come out clean.
*I am Area1320* To view links or images in signatures your post count must be 10 or greater. You currently have 0 signatures. |
Bookmarks |
Thread | Thread Starter | Forum | Replies | Last Post |
Engine Swap and Suspension Install? | Dustin | (Past Vendors) | 3 | 04-28-2010 03:06 PM |
Suspension install cost? | poisonivory | (Past Vendors) | 0 | 09-26-2009 10:58 AM |
Suspension Install | SuperCoyle | Networking: requests and offers | 1 | 08-07-2009 12:01 PM |
shops to install suspension | Vinny | New Jersey | 6 | 07-17-2008 09:21 PM |
suspension install . DONE THANKS TURBOTEKTUNING | CleanNeon98 | Upcoming Events | 65 | 06-09-2007 10:55 PM |
