Old 04-10-2014, 02:45 PM   #1
EliteImports
Former Vendor
Member #8542
1992 Nissan Silvia
Send a message via MSN to EliteImports
I know its been a while but here is a deal for you!!!
April deal on EliteUpgrades.com !!!! Check it out!!!!
The Street Basis damper is the evolution of the popular BASIC coilover. Developed to provide a sporty ride feeling and aggressive stance. The shortened shell case design provides optimum damper stroke at lower than standard vehicle ride height. Vehicle ride height is adjustable via the ZT coated threaded sleeve. Updated internal components and external coatings increase durability and product life. Street Basis dampers are great for daily driving and spirited driving for all types of drivers.
Made in Japan under strict quality control standards and developed by highly trained suspension engineers.
Additional Features
• Steel Construction
• Twin Tube internal construction
• Larger piston diameter for strut type front and rear (22mm)
• Ride Height adjustable via spring seat
• Powder coated damper body
• Non-welded ZT coated Adjustment Tube
• Full-Length Dust Boots
• 1-piece Aluminum Spring Seat with Delrin Thrust Washer
• Available for Overhaul
• 1-year Manufacturers Defect Warranty
Contents of Damper Kit:
Shock Absorber ื 4 Bump Rubber ื 4
Main Spring ื 4* Hook Spanner ื 2
*Some applications include helper springs Dust Cover ื 4**
Seat Lock ื 4 **Some kits will retain use of OEM Dust Covers
Spring Seats ื 4 Instruction Manual ื 1
Delrin Thrust Washer ื 4 Stickers***
***(Note that Stickers do not come included for all JDM part numbers and for certain applications)
Ride Height Adjustable
Vehicle ride height adjustable via a threaded shock body and adjustable spring seat. The threaded sleeve is welded to the actual shock body and then Zinc coated for added protection. TEIN engineers have performed vigorous testing to ensure the best possible position and range of the spring seat to ensure the most adjustability. Aluminum spring seats are utilized to reduce ceasing of spring seat to threaded body, and for improved durability.
Twin Tube Internal Design
A Twin Tube internal design is utilized for increased piston stroke for improved handling and comfort during street use. Another major feature of the Twin Tube design is that is more durable in the case of damage to the actual damper body.
Check out more features on TEINs site. And check out the youtube video on the Street Basis Kit
Don’t see your the item you are looking for? Give us a call 1888-727-3536 or 215-725-0490.
EliteImports is offline
How to deal with PDA. Murderface Off-Topic 18 06-24-2008 02:24 AM
Pretty good deal on monitor "deal of the week" GeforceXtreme Off-Topic 5 12-14-2006 08:17 AM
What is the deal.... driftingeric2k4 Off-Topic 29 08-22-2006 10:10 PM
I'm kind of a big deal... 99SL2_Modder Gallery 8 11-02-2005 06:45 PM
